Results 1 to 5 of 5
Thread: Swingarm Seals
    Feb 2002
    Mitford Community, South Carolina
    509
    Default Swingarm Seals
    ((I originally posted this in the Panhead section but could not figure out how to delete their and decided to post it here also in case I do figure out how to delete that thread))
    I am in the process of rebuilding a '58-'72 rear swingarm and have noticed that I have two different sets of seals, one thicker than the other. Looking in the various parts books and catalogues and even in the four different shop manuals I have, I see that the part number for the drum brake swingarm seal is different from the disc brake swingarm seal but nowhere do I see a reference for thickness. Unfortunately I trashed the parts when I prepared the part for powdercoating so I have nothing to reference.
    Does anyone know which is the correct seal? FYI, I have a Drag Specialities kit.
    Thanks,
    Lonnie Campbell #9
    South Cackalackey, U.S. of A.
    Come see us at the Fourth Annual AMCA Southern National Meet - May 17 - 19, 2013 at Denton FarmPark, Denton, N.C.
    Visit the website for vendor and visitor information at www.amcasouthernnationalmeet.com
    Canada eh!
    622
    Quote Originally Posted by Lonnie View Post
    Thanks,
    Years ago I overhauled a 78 shovel. I wrote in my parts book that the factory swing arm seal was Victor 64323 (this is the later -72 part number). A google search turns up specs that imply that seal's thickness is 4.76mm ... Perry
    May 2009
    539
    earlier ones are thicker but they will interchange. they are the same seal as the later wheel bearing seal. usually the wider ones are used on side glide wheels and thinner ones on narrow glide wheels but earlier swing arms will use either
    Apr 2003
    530
    The fat ones are original, at least through the round swingarms. They carry a 58 suffix. When installed they are flush with the swingarm, the bearing to frame spacer just extending past the outer lip on the seal.
    Kyle Oanes AMCA # 3046
    Feb 2007
    Hummelstown, PA
    901
    Sorry saw the other post first. Posted measurements of actual seals in the panhead section.
    Brian Howard AMCA#5866
