Results 1 to 10 of 14
Thread: Delco Remy Horn
    Dec 2007
    Paris
    11
    Default Delco Remy Horn
    I would like to install a delco remy horn on my WLA (to replace the replica one I have), someone knows if it possible to open the horn back to install it on the wla backet, I tried to remove it but the central back part doesn't move...
    May 2009
    539
    that is riveted together is why---i send my horns to
    HORN MAN
    CHARLES SHAVER
    696 SW 70TH LANE
    LIBERAL, MO. 64762
    417-394-2788
    he is very reasonable and when he's finished the horn is VERY loud and every piece is finished correctly ready to bolt on the bike. is is usually at davenport
    Menomonie, WI
    588
    It is possible. The rivet looking protrusion on the back is in fact peened over the data plate washer. It is part of the round steel "core" that the wire wraps on. If you only have one to do it might be better to send it off because it took me a few times to get the first one right.
    Jerry
    Dec 2007
    Paris
    11
    Does it means that the round plate washer (where is written "Delco Remy 16") is on piece with the rivet...? What happen if I remove the rivet ?
    I didn't find any figures concerning of how is assembled this horn!
    Menomonie, WI
    588
    If you clean up the end (unpeen it) that protudes thru the data plate washer everthing will come apart. I have turned out new center 'cores' or I have used the ones from automotive Delco 16 horns which were sometimes longer to accomodate a thicker bracket.
    Jerry
    Quote Originally Posted by flat-happy View Post
    HORN MAN
    CHARLES SHAVER
    696 SW 70TH LANE
    LIBERAL, MO. 64762
    417-394-2788
    Hey Flat-Happy does he chrome the face also or is this something I have to have done?
    4,254
    Quote Originally Posted by gallen View Post
    If you have a original black painted face I have a friend who will trade you a chrome face for it.
    Chris,
    Thanks for answering. Is the chrome face in good condition as far as dents and is it brass or steel. The one I have has two small dings. I can send some pictures of it.
    4,254
    Chrome faces are brass. Black painted are steel.
    Chris, I would be interested in trading for a brass face as it would be the correct one for my Knuckle. Let me know.
