Results 1 to 10 of 12
Thread: 70 Electra Glide Exhaust
    Dec 2007
    Colorado
    25
    Default 70 Electra Glide Exhaust
    anyone know what pipes I need to add a kicker to this bike and keep the dual exhausts? thanks
    Jun 2005
    Northern Colorado
    437
    I don't believe the factory ever offered any kick start cone dresser systems. It is possible Paughco or someone may offer something, though. If you are willing to ditch the duals, your options increase.
    Default Dresser pipes
    I have a set of Paughco pipes that clear the kick start on my '75. Haven't been able to find a heat shield for the rear head pipe though.
    Jun 2009
    PA
    117
    I did this to a 75 flh for a friend of mine several years ago, I believe the pipes were pauchgo. You will neatly have to cut the stock heat shields for the front header and buy one for a late generator shovel for the rear. I prefer buying aftermarket heat shields to molest as opposed to desicrating the originals. Keep the stock exhaust intact incase your mind changes later.
    Feb 2006
    N W Ohio, USA
    572
    My '72 FLH had a kicker on it when I bought it. It just had two exhaust pipes with a squish pipe to clear the kicker. It is a two into one system.
    Mike
    4,254
    Quote Originally Posted by portagepan View Post
    Mike
    My '72 Stupid-Glide was also kicker. No electric start on it.
    1,408
    You can use the '69 and earlier header pipes if you don't mind the front pipe looking odd sitting out in front of ther engine where there is no cam cover.
    Robbie
    Rubone Amca #2736
    Mar 2008
    yakima wa,
    18
    paucho makes a set of over-under pipes[front pipe under kicker and rear goes over]. also theres true duels[front straight back and rear turns left and comes out above silinoid,running back] hope that helps
    hawg farmer
    Feb 2007
    Hummelstown, PA
    901
    Superglide pipes are completely different than FL pipes. the FX pipes will not clear the big battery for the electric leg.
    Brian Howard AMCA#5866
    Mar 2008
    yakima wa,
    18
    oop's i thought it was for 1970 flh adding kicker; did make me think so i went out to the e-glide shed, i have a set brand new,now thats the over-unders,there made to clear for flh, my 1972 flh came stock with electric/kick so is my 73 and my 74, my 66 came with starter/kicker, i probly read wrong ,hey you guys have a good day, think stock exhaust;
    hawg farmer
