Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: 68 FLH Tillotson Carb Brackets - need help
  1. #1
    Default 68 FLH Tillotson Carb Brackets - need help
    Does anyone have a picture or diagrahm of the throttle and choke cable brackets as mounted on a 68 flh?
    Search all over to no avail.
    Thanks.
    \'77 Sportster
    \'68 FLH
    \'61 Super 10
    \'56 Servicar
    \'59 Hummer
  2. #2
    Jun 2009
    PA
    117
    The 59 to 69 parts book has the diagrahm on both. I have a stock 68 flh except the carb because the original carbs were nothing but trouble for me. I was able to modify an S and S carb with the internal throttle set up and the original air cleaner cover to make it look stock. Ive been running it for years flawlessly if things don't go your way.
  3. #3
    I checked my local HD dealer and the parts book they had did not show it. I'll go back again and check. I found a picture of the bracket set up for the throttle, so it is just the choke that eludes me. I'm told the bracket mounts to the upper motor mount, but it seems like an odd fit.
    The bike had a bendix on it. I'm certain there are better options out there, but for the limited amount of riding I do, I prefer to return to stock.
    \'77 Sportster
    \'68 FLH
    \'61 Super 10
    \'56 Servicar
    \'59 Hummer
  4. #4
    Jun 2009
    PA
    117
    My parts book shows the choke brackets and blow up, I'll try to post a pic but I am not very good at it. My book is Harley 1959 to 1969 flh
  5. #5
    Sep 2008
    grass shack
    79
    Smile part # for 67-71 tilloston choke
    Quote Originally Posted by ratfink View Post
    Thanks.
    In my 1961-1971 amf harley parts book
    part # 29225-67 for the bracket
    # 29220-67 for the choke tube
    # 29216-67 for the choke wire
    # 29214-67 knob
    #7789 for the nut to hold bracket to tube
    # 7608 nut to hold knob to wire
    #575 hairpin to for choke cable tube
  6. #6
    Mar 2005
    Huntington, New York
    363
    Murph,
    I have a 1979 Shovelhead hot rod on which I run as S&S 'E' series carburator. I have been thinking of changing the throttle to internal like the early FL's and Sportsters (no return spring) using the original early handlebars (NOT MODIFIED !), and also mounting an oval (Ham Can) air cleaner.
    Which carb are you running and which air cleaner did you modify? Do you have any problem with leg clearance? Any suggestions and/or time-saving tips?
    By the way - very nice '62 Sportster! I also have a 1964 XLCH - my first bike....
    Thanks!!
    Bill Pedalino
    AMCA 6755
  7. #7
    Jun 2009
    PA
    117
    I will take some photos of how I did it and post it. I ride my 68 fl everywhere and never had an issue. There is some things that need to be done though. The throttle cable needs to be braided like one from the bicycle store. The throttle cable plate on the carb needs to be drilled for the cable fitting end on the carb, the one that is original to the linkerts and tillitsons. and an additional return spring. All will be explained in the photos, if not get back too me. I'll try to post tonite. Also you need cut the weld on the original backing plate neatly so as not too molest the backing plate.
  8. #8
    Oct 2007
    Northern Ill.
    69
    Here you go.
    Dave Swanson
    1956 FLH
    1969 FLH
    1964 XLCH
    1956 KHK
    1936 VD
    AMCA 11659
  9. #9
    Jun 2009
    PA
    117
    Bill maybe I misunderstood, did you want the pics of the modified s+s carb with the stock air cleaner and internal throttle. Or the stock set up that Dave is showing.
  10. #10
    Mar 2005
    363
    I was looking for photos of an S&S carb set up for the original internal throttle.....
    Bill Pedalino
    AMCA 6755
