Originally Posted by
Rub
OldHog66
The three hole gasket is for the clutch derby cover which your '66 does not have. The foam ring is to seal between the starter solenoid and the cover. I assume you got the kit with seals so there is likely one for the inner cover to transmission shaft. There are also most likely seals for the shifter shaft on some models which goes through the inner and outer covers, you don't use them. That is the problem with kits like that. hey try to cover too many years and sometimes don't even have all the right ones for the year you need. The gasket set should have a list of part numbers included. See if it does and what they are. match them up to your parts book to see what you need for your application.
Robbie
