Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Panhead Valve Oiler
  1. #11
    Jul 2002
    5,464
    As with a lot of mechanical items the common name is not what is listed in the book. Your reference to rocker blocks as bearings assures us of that. While politically correct the term bearing is confusing to old farts.
  2. #12
    Feb 2007
    Hummelstown, PA
    901
    Don't feel bad Chris, the other year when H-D switched to "parent material bearings" for their outboard cam supports. We had to see a motor torn down to figure out they meant they eliminated the bronze bushings and were now running the cams in holes bored in the aluminum plate.
    Brian Howard AMCA#5866
  3. #13
    Jul 2008
    North Carolina
    642
    Quote Originally Posted by Chris Haynes View Post
    There is a Shop Dope that advises to remove them.
    Can anyone tell me what is the Shop Dope # for this bulletin or have a pdf copy they can send or post? I read through my repop Antique Cycle Supply (Vol. III & IV) and H-D Shop Dope book (99410-93) and could find anything about the intake oilers. Thanks
    William Edwards, AMCA #10035
