Results 1 to 10 of 13
Thread: Panhead Valve Oiler
    Aug 2005
    Winchester, Ohio
    106
    Default Panhead Valve Oiler
    Gentlemen, I've done shovelheads and flatheads but please bear with me as this is my first panhead. I'm very meticulous about keeping parts in order and when I disassembled the heads, oiler parts #18100-49 and #18102-49 were at the exhaust valve. Did some one assemble it wrong in the past? Or is my parts manual wrong as it states intake valve oilers? Thanks for your help & time, Lloyd
    Sep 2008
    central ill.
    76
    Default top oiler
    every pan top end i,ve ever rebuilt the oiler was on the intake side.
    5,464
    There is a Shop Dope that advises to remove them.
    Aug 2005
    Winchester, Ohio
    106
    If that is the case, let me ask everyone if I should remove the oilers????????? Lloyd
    Jun 2005
    Ohio
    852
    I've got a good 20k on my engine with out them on there.
    Steve
    AMCA #7300
    Mar 2009
    543
    The last time I had the valve covers off my '59, one of the oilers was broken; the little 'dripper' portion of it was found loose, had bounced around a bit and was just laying in there.
    Feb 2007
    Hummelstown, PA
    901
    According to Palmer's book, the use of the oilers is required with certain types of rocker bearings or over oiling will result.
    Brian Howard AMCA#5866
    5,464
    Quote Originally Posted by bmh View Post
    What Panhead has a rocker arm bearing?
    May 2009
    543
    i think they are possibly talking about the little rotator cup that went on the end of the valve stem on 1 or 2 years??
    Feb 2007
    Hummelstown, PA
    901
    17611-48, 17614-49 & 17615-49 rocker arm bearings , as listed in the parts book. From my dictionary, bearing  [bair-ing]; In Machinery. the support and guide for a rotating, oscillating, or sliding shaft, pivot, or wheel. Not all bearings are ball or roller bearings.
