The judges may disagree, but I really don;t go crazy withthe finish. After several months in the oxygen, the aluminum turns and they all look pretty much the same.
I've been using No. 10 glass beads on harley motor and transmission cases for over 40 years. After initial degreasing/cleaning and blasting, I use a soft brass brush to tone down the white appearance left by the glass beads. After a few weeks of oxidation, the aluminum still looks almost like factory castings.
Extremely importand! You must commit to very arduous cleaning in HOT HOT sopy water whenever you glass bead aluminum parts. The metal MUST expand during the cleaning process to ensure that all beads are released from the surface. WHile imursed in the hot wash, scrubbing with multiple sized medium-stiff plastic brushes is a must as well. I use the brass brushes during the cleaning after scrubbing with plastic brushes. Don't forget to ues your small round (1/8"-3/8") round bore brushes as well.
Yes - a lot of time dedicated to cleanng. But in all these years and afer many, many motors, I've never had a problem related to residue abrasive. (Thank God!).
Bill Pedalino
Huntington, New York
AMCA 6755
