Page 6 of 6 FirstFirst ... 456
Results 51 to 57 of 57
Thread: 1965 Pan Questions
  1. #51
    Dec 2001
    183
    Slow down Chris, take a deep breath. I beleive he's talking about the battery cover, not the timing gear cover.
  2. #52
    May 2009
    539
    i thought the 65 was 1 year only because of the over head oiler banjo bolt?
  3. #53
    4,254
    1965 had a cover on top of the battery but no cover on the sides. Just a big black battery hangin' out. The -65 part number battery cover did not appear untill the fall of 1965 and the 1966 models were in production then. Motorcycle Goodies made a smooth aftermarket chrome cover that was used on a lot of 1965 models.
  4. #54
    Mar 2009
    Princeville, IL
    76
    Chris,
    I noticed when I took my ribbed cover off and just had the top cover on the battery, there was about 1/8" clearance on each side at the cover and also at the battery box. I measured another big battery I had and it was the same size as this one. Do you think the orginal batteries were slightly larger at the top and bottom. In the picture it kind of looks like the center area where the logo is might be slightly smaller.
  5. #55
    4,254
    Quote Originally Posted by Underdoggie View Post
    Chris,
    That is just the way the top covers were made.
  6. #56
    Sep 2004
    983
    Chris thats funny mine cover camre rapped in a paperbag material sealed from the factory with a sticky HD orange and white paper !
  7. #57
    Jan 2007
    Lawrence, KS
    63
    Default Hi All...
    I have to weigh in on Chris' side of the fence on this one. The ribbed cover, while widely accepted and seen on 1965 Pans, did not come out until late 65. That said, the judges will likely accept this cover because it can be classified as an accessory and, therefore, not judgeable. That doesn't make it correct, just acceptable to have or have not.
    I read the thread from a ways back about the member who was dinged for not having the cover or the M/C cover. This is simply an incorrect call by the judge. Fortunately, 1/4 point does not make or break a machine.
    It is possible to get a deduction for not having a kick spring cover if the bike is outfitted with the King of the Highway package. This cover was part of the option and, while an accessory per se, I always make a note, at least, to let the owner know of the omission.
    Stay upright.
    George and Kyle Marakas
    K & G Cycles
