Results 1 to 6 of 6
Thread: JDH rockers
    Menomonie, WI
    596
    Default JDH rockers
    Can anybody confirm or refute this as a JDH rocker arm.
    Thanks Jerry
    Nov 2001
    222
    Jerry.
    I think it’s the later rocker with the larger bush 105-29 the parts book says its for 1929 61 and 74 inch twins and later 1928 H motors.
    Pete Reeves 860
    West of the Muddy Mo'
    88
    Default JDH Rockers
    I believe Pete is correct Jerry, the inlet lever in your post fits either of the later inlet towers. The Standard or L motors versions as well as the H Motors. The later standard motor version (98-29) is on the right in the image titled inlet housings and the H version (98-28) is the one pictured in the other image.
    Are you workng on an H motor?
    Glide
    Nov 2002
    France
    65
    Default Rockers
    Here find a picture of JDH rockers
    Menomonie, WI
    596
    No I do not have a H model. I have a real rough 1925 JDCA and I am doing nothing with it. It was given to me years ago by a local farmer. I ended up with a couple of those rockers in a pickup load of parts I bought the other day.
    Thanks everyone for all the info.
    Jerry
    88
    Wink JDH Rockers
    Jerry, I see there is a JDH basketcase for sale on George's site. Maybe you could build one around that inlet rocker?
    Glide
