Results 1 to 7 of 7
Thread: Pre-41 Front Brake Shackle
    Mar 2008
    Jacksonville, FL
    179
    Default Pre-41 Front Brake Shackle
    Have a shackle XF-834, and am not sure of the casting # for various shackles. I have researched Palmer on what I thought was an original early Big Twin shackle, but some things aren't consistent with Palmer. It's 6" long, but looks closer to 33/64" wide at the blade. also, it has two grease fittings. Maybe wear and someone adding a grease fitting explain it, but just wanted to know if anyone can share definitive info based on the casting number? Thanks, Vic.
    Jan 2008
    104
    This one is about 6-1/8" center-to-center. Does your forging appear to have been plated and/or stripped?
    Mar 2008
    Jacksonville, FL
    179
    Tim, That's it ... it may be a hair over 6" center to center. Can you tell me what it is? Big Twin 1940, I hope? It looks like it's older parkerized, and I don't think it's been stripped or plated.
    Thanks,
    Vic
    Jan 2008
    104
    I believe it's a '36-38 because of the two grease fittings on the sides. In '40, the rear fitting was moved to the pivot stud.
    Dec 2003
    409
    no boss on grease fitting area on 37
    Mar 2008
    Jacksonville, FL
    179
    Default 1940 Big Twin Shackle Casting #
    Can someone with a correct 1940 Big Twin front brake shackle tell me what the casting number is on the shackle? Thank you.
    Sep 2007
    Salzburg
    8
    Cool
    Quote Originally Posted by 40 Nuck View Post
    mine has XF 834F
