Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Chrome removal
    3,649
    Default Chrome removal
    I chose this catagory because removing chrome must involve tools. I have been trying to strip the chrome off a pair of fork rockers and I'm getting poor results. I found a forum on the internet that discussed using chemical stripping with muratic acid to get the chrome off and sulfuric acid to get the nickel off. You set up a bath and use a power source, just like plating. The bath should be 2 parts water to 1 part acid. They suggested using lead as the annode. This worked great for the chrome which came right off. The nickel is another story. I have had the part in the sulfuric bath for hours using a trickle charger for the power source. I have seen virtually no removal of the nickel. My second assault on the nickel has been with a sandblaster but I just don't have enough compressor for the job. My final method has been to use die grinders, belt sanders, files, and sandpaper and that has worked but it's miserable and gets into the rocker itself. I'd love to hear about a better way.
    Sep 2006
    Cleveland, Ohio
    178
    eric,
    Do you have a link to that forum, I've got a bunch of stuff on my Pan that has been chromed over the years, and I've heard it is probably easier & less expensive to just replace the parts rather than take them somewhere to get de-chromed. I'd like to try your method first though, and would love to hear other input as far as removing chrome. I would also like to hear ways to prep a chromed part for paint, I've heard it's possible to do that also...
    Mike
    3,649
    Mike, I just typed "Chrome stripping" in the MSN search engine. I got hits from a Caswell forum and a few other places. I printed it out but don't have the information with me. I know what you're talking about with the pile of old chrome plated parts. If it's stuff you want to Parkerize then you have the problems I have. If it's something you want to paint, just give it a light glass beading or wet sanding with wet/dry sandpaper. I've been using an epoxy primer on bare metal and chrome and that has been working well for me. Let us know if you find some good information on de-chroming.
    Jul 2003
    world famous lowell, massachusestts
    13
    Default stripping of chrome plating
    we send plated parts to browns plating if we need the plating stripped, they will come back as bare metal ready for paint or cad plating. we are a dealer for them and have done this time and time again.
    Feb 2006
    N W Ohio, USA
    580
    Could you give me an example of how much they charge for this? Does Brown's in Kentucky
    do this too?
    Mike
    3,649
    I'd like to know too. The platers in my area flat refuse to do chrome removal and I'm fed up with trying to get it off with the methods I've been using.
    Feb 2007
    Central Oregon, High Desert
    234
    While were on this topic, how about chrome removal on aluminum? I've got a pair of 'Glide sliders and front backing plate I'd like to rescue.
    Doug.
    Sep 2006
    Cleveland, Ohio
    178
    I'm also facing the same thing, chrome over aluminum, chrome over parts that were orginally parkerized, chrome over parts that were painted... Oh well, we all know some people had a lot of fun with these bikes in the 70's, now we're paying the price when it comes time to restore them. Any additional info would be appreciated.
    Mike
    iowa
    193
    the last time I had nickel removed the guy said he needed more amps than he had so I gave him a old 200 amp battery charger/starter. he cranked it up to about 50 amps then it came off. wish he was still around
    Feb 2007
    234
    Default Chromed Aluminum
    This thread just kind of petered out..... I was hoping someone might have some good ideas for removing chrome from aluminum parts, such as 'Glide lower legs etc. Any comments?Doug.
