Thread: Indian Motor sprocket wrench
    stan Guest
    Default Indian Motor sprocket wrench
    There is a tool out there to hold the engine sprocket, and thghten the sprocket nut at the same time. Has any one tried this tool? Stan
    Jul 2008
    Richmond, IL
    195
    I know this post is almost a decade old, but does anyone have any pictures or suggestions of what they use?
    D.J. Knott
    AMCA #10930
    Aug 2009
    rural eastern South Dakota
    934
    Quote Originally Posted by Knotthed View Post
    Should find it in the special tools section of any of the Indian parts dealers.
    I made mine, a copy with fewer "bolts", and it required a little time on the lathe and mill, took several hours, but I use the heck out of it.
