Results 1 to 5 of 5
Thread: 45 Oversized Intake Valve
    Rex Guest
    Default 45 Oversized Intake Valve
    Where can I get a nitrided 1 13/16" intake valve for my 45?
    koanes Guest
    Kickstart Motorcycle Parts offers a 3/16 OS valve, not USA made, but I haven't had any trouble when I had to use them. Not sure about performance application. Rowe USA has an 1/8 OS #753-03, forged, shot peened, black melonite, high quality. Not quite big enough?
    Rex Guest
    I did see that valve listed in the KS book, but was holding out for a nitride type. Cotten directed me to Kibblewhite, but they don't offer my size either. My motor was rebuilt with 1 13/16" intakes.
    Any opinions on valve guide material selection? So far I've seen chilled steel, cast iron, and ampco 45. I like the cast iron just because it seems like it should grow and shrink at the same rate as the cylinder.
    This motor has an M88 with adjustable high speed needle, +.040 pistons, #6 heads, and WR pipes.
    Durability at highway speeds is the major concern for this project.
    Jack_Hester Guest
    Rex -
    Manley will make you any sized valve that you want. I had them make some oversized H-D 45" valves for me. I sent them a NOS sample valve, along with the head specifications that I wanted. They were perfect for the application, and the price was very reasonable. Other valve manufacturers will do the same, I'm sure.
    Jack
    koanes Guest
    KickStart #3420 3/16 o/s intake. Doesn't state whether they are nitrided or not. When I purchased them from another source, they were. If you call Chuck he will let you know.
