I need a referral for a good Linkert rebuilder. I am throwing in the towel.
Hey John, after I recovered from my weekend stupor and also warmed up some, I was thinking you might want to check your manifold nuts for tightness and take a look at your points. I'm sure your carb needs work the way it was acting but with the motor work just completed it wouldn't hurt to check everything else too.
This is one link I got when doing a google search.......
http://www.genuinecycle.com/linkert.html
Good luck
You should consider our very own Cotten for your rebuild. Here's a link to Liberty's website ... Perry
As found in the latest Walneck's................
Mike Millay
6825 Park Lane
Waterford, WI 53185
262-895-6838
mmillay234@aol.com
Mike has to be good: He uses my floats!
A note on manifold nuts: "tight" means nothing.
Please pressuretest the assembly with soapy water. A discussion of this is posted at http://virtualindian.org/11techleaktest.html
Good luck,
