Results 1 to 10 of 15
Thread: 4 cylinder woes
    cscott Guest
    Default 4 cylinder woes
    i have a 1940 4 cylinder that runs great, starts great,but after about 30 minutes it takes alot more power or rpm to re-engage the clutch without stalling , anyone ever heard of this or know where i should start, thanks once again chris
    charlie frey Guest
    I don't totally understand the problem.
    Are you saying that the bike is more prone to stalling when hot, so you have to rev it and slip the clutch more?
    cscott Guest
    yes, after its hot i have to increase the rpm to keep it from stalling as i let the clutch out, when its cold everything works fine?? thanks chris
    charlie frey Guest
    Do you also notice a loss in power once you're moving?
    Any missing or popping?
    What do your sparkplugs look like?
    cscott Guest
    no loss of power once the foot clutch is released its fine, it only shows the need for extra rpms engaging the clutch, thanks chris
    exeric Guest
    Did you ever solve this problem ? I would be curious to know what you did to resolve this.
    cscott Guest
    Default 4
    no, i have the bike apart now for repainting, i will tackle that problem again in the spring.
    exeric Guest
    This problem sounds very similar to a problem I had with my 1917 Henderson last year. I had just finished rebuilding the engine and thought I would drop it in the unrestored frame to see if everything did what it was suppose to do. Like all 4 owners, I treated every component like it was an eggshell and went to ridiculous pains bedding the crank and getting the caps torqued just right so everything would spin like it was in outer space. The great day finally came and it was time to see if it would start. To my joyous relief it started after a few kicks and sounded smooth and mellow. Getting an old motor to run after God knows how many years is one of the great pleasures in life, it's right there after your first . . . . . Well, I better not go there. Anyways, I'm standing there, basking in the glory of my great accomplishment when I thought it would be interesting to see how it would ride. I pushed it off the rear stand, took a seat, and touched my foot to the clutch pedal. The engine made a scream that sounded like a pig with it's balls in a vise. I about s**t myself and immediately killed the mag. After regaining my composure I started it again, which it did with no problem, however the slightest pressure on the cluctch pedal would bring back that scream and more pressure would labor the motor. Boy, did that ruin my day ! After a few days of self pity (and loathing) I got the motor up on the bench and pulled the bottom pan. I fully expected to see some serious galling on the bell housing because I figured I screwed up the the endplay somewhere. Once inside I saw no evidence of anything wrong. Everything looked great ! I'll cut to the chase because this is getting a bit long-winded. I noticed that the clutch release arms didn't have even contact on the throw-out bearing fingers (dogs). In essence, one arm pulled unevenly on the throw-out bearing. I still didn't know if this was the problem beacause it didn't seem that far off. Anyways, I had to pull the crank (watch it ! ) and rotate the throw-out bearing 180 degrees. Contact with the throw-out arms to the fingers looked better so I put it all back together with grave doubts. . . . We're almost at the end now. I gave it a few cranks and the motor fired up. . . . Now for the nail biter. I touched my foot to the clutch pedal and Hallelujah ! The sun shown down on my worthless soul ! Smooth as silk . . . . Except for that wirring noise in the gear chest, but that's another story.
    c.o. Guest
    Eric, feel free to drag on stories like that! It's what makes life interesting!!
    cscott Guest
    Default tight 4
    thanks for your reply eric, that makes sense except the clutch works fine at first and i dont have any problem with it until about a half an hour later when the whole engine comes up to temp,i did not build this engine so i dont know, but i hate to say it but i think there could be a problem with crank end clearance, i hope someone can tell me i am wrong. thanks chris
