Results 1 to 4 of 4
Thread: 32 e gen
    cscott Guest
    Default 32 e gen
    i have a 32e gen. and all the internals look great, but it is an oily greasy mess inside, does anyone know the proper way to degrease the windings?? thanks chris
    Lonnie Guest
    I have had good luck with the spray-on (in a can) brake cleaner - same as electrical contact cleaner now sold, but at 1/2 the price. Be careful, it comes out fast and will blow the crud all over you if you are not careful how you aim it.
    Lonnie
    Ken Lee Guest
    Default 32e gen
    Hello Scott , I've always found the best way is to take apart (label or make note where the conections go) except the field windings and clean with carb cleaner , (an aerosol spray cleaner , you must be able to get it over there ??) clean all up with that and reassemble , the 32e's do get a bit oily in long service , best of luck , Ken
    cscott Guest
    Default 32e
    thanks guys for the info,
