Results 1 to 2 of 2
Thread: 36 four frame
    stan Guest
    Default 36 four frame
    I would like to remove the lock assembly from my frame. All I see is a pin at the bottom of the lock assy. How is the lock assembly removed? Where is a good source for pistons.All i can find is sets for over 400.00 seams a little high. Stan
    AdminGuy Guest
    Hey Stan, Drill out the pin to appropriate depth. Greer has pistons as do others.
