Results 1 to 4 of 4
Thread: 36EL Rims
    stevemc Guest
    Default 36EL Rims
    Is the rim in the photo a 36el rim or a 45 rim??
    Palmers book has a photo that looks the same as this rim but the man that sold it said it was a 45 rim.
    Any help would be appreciated!!
    Steve
    Lonnie Guest
    It is a Big Twin wheel, an 18". VL's (19") and 45's are opposite on the spoke holes in relation to the valve stem hole.
    stevemc Guest
    Before the reply I was looking in the Knucklehead Restorer's
    Guide by Greg Field. On page 39 Dave Bank's unrestored 36 is the oposite of the one I bought but the restored bike on the cover is the same as my wheel---what is correct??
    Trying to get it right.
    Steve
    Carl N. Olsen Guest
    Steve,
    Hold the rim in your hands with the valve stem hole facing your feet, look on the rolled over edge, if it is a big twin rim, it will have one hole drilled in each bead, if it is a 45 rim it will have one hole in one bead and two holes in the other.
