i found a corect Adam Bagnal Horn for 15 Harley, Excelsior,wery rare including Mail 650 .-can bring to Mannheim
Printable View
pictures please
thanks, my 15 is a mag model, so i need a mechanical horn, not electric.
Is it ‘17 & up HD green?
Green is the correct color for early 1917 and up but that horn Ulf has pictured is a 1915 only style. You can tell from the mounting bracket and the locations of the holes in the horn where the bracket attaches.
1915 is slightly different from the 1916-1919 version.
Mark
‘15, ‘16 & ‘17 all have a subtle differences...
It looks like a ‘17 with a ‘15 bracket but i don’t know.
Early parts book in ‘17 show each year different body’s, electrics, etc... and some same parts
I need a ‘16 for a 1 owner (all original) that hasn’t run since 1945 missing the horn and headlight.
I’ll try to upload the parts book page
Not sure of a difference between 1916 and 1917 apart from the color difference. That would give it a different factory number but the steel under the paint would be the same.
There may be some subtle change to the points assembly.
There are also at least 2 different brackets 16-19 so if the horn is an assembly, it could have different part numbers from that as well.
BTW: A 15 bracket won't fit onto a 16-19 horn body as the mounting hole pattern is different.
The cover on a 15 horn is unique too. The A-B tag is attached at the center with a rivet and the cover is attached to the horn body with an off center screw. 16-19 horns have one screw in the center to attach the cover to the body and that screw also holds the tag on.
The horn Ulf has pictured is a 15 horn body, bracket, and cover that have all been painted green at some point in the last 100 years.
Mark
Mark was perfectly explain this Horn its a 15 Horn and Works,on my 15 Electrik was missing this peace never found one it has a 16 Horn but the Bike is sold,and now i found a Corect one Plate extra From Adam Bagnal 45.- including Mail my last
